i don't want to go
  • Thread starter Thread starter ocraM999
ocraM999
Why the escalation created in the family window using the command, creates > empty > ...bla ....bla...., does not elicit (not empty) ?
verifying in the properties of the groovy (the solid/empty I mean) seems to me correctly as a subtraction solid but remains there inerms with its very sad orange color.
this with revit 2013.
Mar
in the image you posted also have an opening created with the opening command?
if you do not cut it neache with geometries size.
returning to the question
I think it's a question that shouldn't have an answer(I better explain not to take it personally)
If an object does not behave as we want there could be a thousand reasons, one on all as it is designed from the point of view of the programming code .
a subtraction solid does not cut a guest (wall for example)
and it is right that it is so for many reasons (but this is another speech)
If you don't cut it, there's a geometries command that solves the problem.
