Ritagatto71
Good morning to all I'm getting crazy with a series of 3dfaces which, however, have holes that I can't see and don't turn into solid or transform into solid from surface or with sculpting anything....... is there a way to see where the holes are? I also tried to find them on about 4200 3dface and to fix them by pulling the heads of the faces but it does not seem to work the command always the same message not to be able to generate the solid.... .
I leave from an obj that meshlab already gives me with holes that I turn into dxf to be able to work with autocad mechanical 2016
If I have a suggestion you are welcome... .
