Ritagatto71
Good morning to all my name is rita and I am new in vs. discussions I found very interesting; I don't know how much I can help you, but I'm going to do it if you read my demands.
here is my.........
I have a series of 3dfaces and I have to turn it into a solid... .
I'm getting crazy with a series of 3dfaces that, however, have holes that I can't see and they don't turn into solid or transform it into solid from surface to sculpt anything..... is there a way to see where the holes are? I also tried to find them on about 4200 3dface and to fix them by pulling the heads of the faces but it does not seem to work the command always the same message not to be able to generate the solid.... .
I leave from an obj that meshlab already gives me with holes that I turn into dxf to be able to work with autocad mechanical 2016
If I have a suggestion you are welcome... .
here is my.........
