valeriob
Good morning, everyone.
I have joined two questions in the same discussion.
I wanted to know if it's possible to "constrain" mastercam to eleborte the code
machine(iso) using only i-j syntax for processing
radiated paths, complete circles or parts of them. Now the code that develops me is mixed, a little with i-j and a little with r. the problem is that if an interpolation
created with r is read by a wild control, this reads it not as a radius but as a rapid (gzero reaction) or more simply there is an alarm. Are there any settings at the level of options to check?
the other question is related to the "propagation" of a processing.
Suppose we have a hole to empty with helical contouring on a
face and have on the same face the same repeated processing enne times
having only one piece origin.
can you mill one hole and tell it to repeat it for example 5 times in x at a certain distance and 10 times in y at a certain distance, perhaps using a subprogram (magari in incrementale) in order to use only one origin? If yes, can you also apply polarly? on a horizontal cutter would be useful.
