i no longer see the layout space set with the panes
  • Thread starter Thread starter Alex97
Alex97
I came out of the loyout view that I had set up with its windows, square, cartiglio, I came back and I only see the black space, all the setting probably I clicked some wrong button, someone knows what button I have to restore?
different causes:
- you may have turned off the layers
- you may have deleted the layout
- you could be on a different layout
then try to go back with the cancel command
I zoomed in?extensions and reappeared in another spot of the viewer, I don't understand why the viewer automatically placed on the black box in loyout and the design instead was at a point with the gray viewer, perhaps launching the print in pdf the viewer is automatically placed on the black rectangle? Thank you.
the black rectangle is your sheet
when printing from extensions or with window select the actual area to print and then apply changes to the layout so they are stored
