i see
  • Thread starter Thread starter ansyolitico
ansyolitico
can you in a set put in transparency only a few groups and leave other visible so that you highlight those parts but at the same time show all the parts if together?
I mean something like that.Immagine.webpI thought of changing the material's propie and making it become transparent, but I have to select every single object belonging to each group and change it in transparent...but the groups are many...it really takes a mess of time that unfortunately I do not have
(The image does not come from direct, I took it from internet to case)
with multiple selection you can select more details one after the other, then finish your right click list, go into ownership part and from the transparency "semi" at the same time to all the selected onesSelezio multipla.webp
Today I tried but unfortunately when I go to select all the parts I get implanted... I think they are too many parts
I would have another question to ask you.... how do you draw the panels of the main electrical commands...that is, those who command the industrial machines where each button has its own precise symbol... how.i design those? 3d? no because I tried the 2d I put a barrel of time only to draw half symbol and above all I do not have automatic sampling
It seems strange to me, you usually plant if you select all the faces or all the edges, but selecting the parts not.
then cmq I understood that it was a selective selection that is few parts per group and not mass.
As for the symbols I did not understand well, but if it is a thing like the cetop symbols for the oleodynamics are to be downloaded in dwg format and then manage them as parts or blocks directly in the 2d
