hello to all:smile:
Can you tell me where it is, in the drop-down menu, the "layer axe"? has this icon and also in which toolbar is located. I need to associate a material with the layers.
I just can't find him:
if I remember from the menu render the curtain of the material menu completely parade and there you find the command.
in any case keyboard: _materialattachach
found, however only if I put the interface of the last autocad.. . If I stay with that old one, like cad14 to understand, with classic drop down menus I can't find it
It makes perfect sense. autodesk now from 6 versions is migrated to new interfaces based on .net4. Why should you still keep the old ui with menu and toolbar? among other things in autocad 2015 the work area "autocad classic" is also disappeared, while in other products such as architecture and civil3d has been raised for at least 3 years. You want that command? Customize the menus and toolbars with the command.
