Dibe
Good morning to all,
I ask politely if someone is able to help me find the solution to the following goal:
use a data field for a "point object" that tells me the coordinate y but referring to the local (non-global) ucs.
using the "id" command provides me with the correct co-ordinate relative to the local ucs but needs a data field that is updated according to the position of the "point object".
I found only the data field that only refers to the global ucts.
Thank you for your cooperation.
