id parametric punch sheet
  • Thread starter Thread starter Ilario
Ilario
hi to all, according to you it is possible to give the id of a sheet punch (file.ide to understand us parametrized just as punch and not as classical ifing) the "parametricity" of the values of some measures of the ifeature?
I explain in detail, I have the classic asola created as a sheet sting, I would like that in the id of the sting they parameterized the diameter and the interasse of the asola in order to be able to use them on the table.
I tried to put the two parameters as "export" and to write the formula in the id (as you do for iproperties), but it does not work.
Has anyone already had this need?
Thank you very much.
