identify references between groups and details in the workbook
  • Thread starter Thread starter alessandroM
alessandroM
Good morning
currently my workbook is full of old details that no longer serve (due to repeated changes).
I need to clean it out of unnecessary details, do you know a simple method to identify only the details actually mounted in the axieme?
thanks in advance for your collaboration
a greeting
alessandro
open from windows the folder path where there is the axieme, dx key on the main assembly file, and choose "pack and go" from the drop-down menu.
This command creates a copy of everything you need to do that together in a new folder.
Alternatively you can also make dx buttons on the parent set, alerts design assistant, and see which files are actually used. ps: I often use this method when I need to rename files and at the same time locate "good" files:finger:
