Antodima77 Guest Mar 14, 2022 #1 good morning to all, creating flat model I can not see the fold lines, which I usually see as a stretch and point, to someone happened and know how to solve? Thank you in advance
Cast16 Guest Mar 14, 2022 #2 I don't know if it's your case but try to look here: https://knowledge.autodesk.com/supp...tal-flat-pattern-are-missing-in-inventor.html
Antodima77 Guest Mar 14, 2022 #3 I solved with escamotage. developed by eliminating all processing except the first, lines appeared on idw then I added the remaining
