idw - subassieme highlighting
  • Thread starter Thread starter Christian76
Christian76
by curiosity...:rolleyes:
given a set called a, consisting of smaller assemblies such as "b,c,d,e,f"
Is it possible in an idw where I go to put on the table the assieme "and" insert a 3d of the axieme to emphasizing (with thicker lines) the axieme and in order to make understand where this will be inserted in the main axieme to?
I don't know if I explained correctly (? )
:biggrin:
Yes!
I would say to put the 3d view of the axieme to
in the template tree, within the view, select the axieme to
right click, property, remove "bylayer" and in his vex put the type of line and the desired thickness
all the view now will be, for example, in line stretch-point
now, always in the tree, select the subaxieme and in the axieme to, under the 3d view
still right click and property, though remittaching the check to "bylayer"
