idw with double ipt
  • Thread starter Thread starter Alberto1961
Alberto1961
do you know if it is possible with inventor to create an iwd table containing two different ipts? Thank you very much
if you have opened 2 ipt files, go to the table idw -> position base view and from the menu "file" select the 1st ipt, then place another base view and always from drop-down menu "file " select the 2nd ipt
attention to the choice, the cartiglio will take as the main component inserted.
