if 20 => part => floor creation by 2 points
  • Thread starter Thread starter luca_dic
luca_dic
Bye-bye to everything.
I need to create a building plan for a straight (or 2 points a and b if you want) perpendicular to the front xz floor.
I couldn't.
Can someone give me a tip?
I attach an image to clarify the condition.
if you first make a normal plan to the curve (line ab), and then a perpendicular plan to the normal plane to the curve. I hope I understand the problem well.
Bye.
do a horizontal segment that starts from point to point to side (referred always to point a) on the floor (yz).
Bye.
You know I'm trying, but I don't get it anyway?
The only way I found is the following.
make a normal plan to the right ab
make a parallel plane to the top floor passing by
create an angled plane with a rotating axis the intersection of the two previous floors, and passing by b.
That's pretty slender.
Can you get me a file if you send me?
make a normal plan to the ab curve, on the new plan draws a segment, so you have three points and you can do in plan for three points, I think focus meant this in his post.
Bye.
Bye.
by now I think I understand that, to realize the plan I need, I have to add or 2 floors or 1 floor and a curve.
sin, other cad have direct command plan for 2 points and perp. or parall. to another floor.
thanks for the help
thanks for the help
what systems are you talking about? I was trying with swx but I can't, even in the way I showed you in the attached file (maybe it depends on the fact that I'm still not competent enough on this cad).
for work I also use other cad.
proe wildfire has the passing piano function for 2 parallel/normal points to another.
When I get back to the office on Monday, I see if I can help you.
thanks for the help
just add a sketch, then you can make the plan for 3 points.
