Leakim
Hi, I'll put my problem... I have a small project, in this project I would need to print
in 3d three wheels, 2 of the same diameter d, and a wheel of 1/2d... so that by connecting the two wheels of diameter d with an axis,
equally... one of the two wheels with diameter d must be dented so as to turn in reverse the smaller wheel (also dentate) making them do 2 turns for each spin of the larger wheels...
questions: Can a precise gear come with a cheap 3d printer? What diameters do you recommend me to have a gear that turns well?
3d design tips??? exist downloadable files that can be used for a 3d print of toothed wheels one double of the other? ? ?
As you may have imagined, I'm not a designer, and I'm at first sight... I ask patience and a manina:d thanks in advance!
