image size rendering
  • Thread starter Thread starter mobile75
mobile75
Hello everyone, I am new to the forum and world cad 3d and rendering.
use inventor in the pro 2012 version.
I have this need: a colleague has created various projects and I have to make photos (using rendering). the result must be simple. the problem that having a hundred different designs I have to make so to get an image format png 1929x1080 72 dpi all with the same scale or size. I thought I could just open the project and without zooming or adapting to the screen... but it didn't work.
The drawings are all 1:1 scale, but I don’t really know how to zoom or scale.
Can someone please give me advice and explain it very clearly?
Do you want to clarify your problem better?
What do you mean you don't want to zoom in and adjust your screen? The program doesn't know what you want to get.
Bye.
Bye.
I have to get images of different projects but that have the same size, I make an example.
in a project I open a design (.iam) home1 and genero through inventor studio a rendering saving the image in png format 1920x1080 to 72bit.
Now, I open another design (.iam) home2 and in the same way I generate an image.
My problem is that the size of the two "cases" if they are refined are different, as if they were zoomed in despite the scale of the design is 1:1 for both.
It is as if one of the two (though they are dimensionally equal) has a larger or smaller image. other example house2 which has bigger dimensions of home1 generates a smaller image, which I don't want.
Am I clearer? I hope so.
you want autocad xp zoom!
I'm afraid you won't, the inventor's zoom is only: dynamic, window or everything.
Actually there is also the possibility to set a home view, but it is not controllable with numerical values, zoom, ruoti and when you like the view, congeli and use it as default.
I could propose you to insert your assemblies into a sphere (made with a surface so you still see what's inside) with the size such as to contain your bigger project, zoom everything, freeze the window, remove the ball and generate the png and so on.
100 iam is suicide.
I don't know, let's see if some macro wizard has some sort of solution.
Bye.
in alias studio it is possible to copy and paste the "views" (actually the rooms) as if they were objects. Is this possible?
