impianti di board
  • Thread starter Thread starter Exatem
Exatem
in this debate http://www.cad3d.it/forum1/showthread.php?36929-star-wars we mentioned the production of fresh water on board the ships. the ship contains numerous plants, both for production and for disposal and it is often complex plants (think of a passenger ship with a few thousand people who eat, drink and produce waste of all kinds.
I therefore thought to describe the functioning of some of them starting precisely from the production of fresh water.
water production plantsfresh water is produced on board the ships, for the most different uses: steam production, lavender water and for hygienic uses, drinking water, rockets in cooling circuits and air conditioning. production plants are divided into two main categories: Dissalators and distillers. in practice the different types of plants for the production of fresh water differ because they act by exploiting the phenomenon of osmosis (inverse osmosis plants) or by means of a heat process of evaporation and subsequent condensation (evaporation plants).
the dissalators lower the total content of dissolved salts in the sea water so as to allow the use of water so produced as lavender water, possibly as drinking water after appropriate treatment and finally, as reserve water for the requirements of the motor apparatus.
given the characteristics of the water produced by means of desalination plants this is not suitable as food water for naval propulsion or auxiliary boilers for which these plants are mainly used on units with endothermic motor devices (diesel,tag etc.).
distillers produce fresh water through the evaporation of sea water and subsequent condensation of steam and consist of two parts: a evaporator, in which salt water enters which heats up to obtain steam, and a capacitor in which the steam condenses in distillate.
once the sea water was heated through a tube beam placed inside the evaporation chamber (tuber bundle evaporators). Then it went to evaporators called “flash” in which salt water is first heated and then put into the evaporation chamber where it finds a lower pressure of the steam voltage obtaining an immediate evaporation. this solution has the advantage of lowering maintenance costs resulting in the formation of limestone deposits on the pipes. flash evaporators are often made with multiple standard evaporation chambers on the salt water circuit (fall evaporators), each at a lower pressure than the previous one, so as to increase the amount of evaporated water.
in both solutions, the evaporation chamber is maintained at a lower pressure than that environment by usually allowing the evaporation to 60 °C (low pressure evaporators) and for this reason, it usually takes advantage of the heat of the cooling water of the engines to feed the heating coils, this method allows in fact to elevate the temperature of the sea water to about 60 °C even if the evaporation occurs at low temperatures, such a guarantee for this reason it is forbidden to evaporate in port and it is not advisable to do so in coastal waters especially if the production is sent to the deposits of lavender water.
the production of steam produces a liquid residue with a high concentration of salinity called brine: in a modern plant is produced almost a liter of distilled water for each liter of sea water.
the dissalators instead exploit the phenomenon of reverse osmosis and are very used on board the ships since, in the face of a greater cost, they have greater reliability and need a limited number of auxiliary equipment.
These systems exploit a principle for which when two saline solutions in water having different concentration are put into contact through a semi-permeable membrane that does not allow the larger molecules to pass, water tends to pass into the most concentrated solution by diluting it.
the process goes on until the difference of pressure on the two faces of the membrane, consisting of sheets of polyamide or other materials of poor mechanical resistance supported by plastic support networks, reaches a specific value for that solution, called osmotic pressure, which for sea water is about 7.0 kpa every 100 mg/l of salts in solution. to increase the production of a plant are put in parallel several cartridges and to improve the quality of the distillate they can be put in series regarding the flow of sea water. the advantages that reverse osmosis dissalators have towards conventional distillers are mainly:
- possibility of directly producing drinking water, more suitable for food and lavender use than distilled water.
- functional autonomy
- low energy use
- possibility of using extremely simple plants such as conduct and maintenance.
to obtain drinking water, the simplest plants are usually sufficient or those with a single desalination stage.
in any case, whatever the plant, the water obtained must contain a low content of salts. a good evaporation distiller lowers this amount to some units, while a reverse osmosis distiller leaves higher traces, but always less than those imposed by the oms (although the quality of the plants is continuously improved).
dissalatore-per-distillazione-per-navi-31046-214585.webpevaporatore flash.webpdissalatore-a-osmosi-inversa-per-navi-36651-368531.webp
As for the needs for onboard uses, it is considered a standard consumption of 70 liters per person per day on a merchant ship, therefore for the crew. on a military ship taòe quantity is reduced to about 40 liters, while for a passenger ship, being greater the requirements both directly of the passengers, and for the services connected to them (cucine, lineage, etc.) refers to an average consumption of 225 liters per day per person.
on the merchant ships moreover can be requested sweet for the reintegration of the steam for the auxiliary plants of the services hull, as for example for the heating coils of the cargo of an oil ship.
lavender water
the fresh water used for sanitary uses (kitchens, toilets, etc.), while drinking water is obtained from the same for drinking water.
the fresh water for these purposes is boarded, at every stop in the port, by means of sleeves connected to a special grip on the deck and sent to chests covered with non-toxic paints to ensure the maintenance of the chemical-physical characteristics of the water.
distribution on lavender water vessels (cold or hot) to cabins and service utilities (e.g. kitchens), is carried out through an autoclave, but simpler methods such as the use of pressurized accumulators or the use of only pumps can also be used. in older plants the task of the autoclave was carried out by a case of gravity.
with regard to the water needs on board, many are the utilities that need distilled water: the main user is the air conditioning system but also the plants for the production of steam. Moreover the distilled water at the temperature of some degree centigrade is especially useful on board for different cooling requirements of electronic or electrical equipment. the water is in fact often used as an intermediate coolant to avoid convoking along the ship polluting and corrosive cold liquids that it is preferable for safety not to circulate in the ship.
drinking water
a reserve of drinking water is often pre-packaged in bottles (mineral water) while the one produced on board is used for this purpose only when the stock finishes.
as we have seen the distilled water in low pressure plants or in reverse osmosis, it does not reach temperatures sufficiently high to ensure sterilization therefore a process of drinking water produced is necessary. Moreover, in case the water is produced for reverse osmosis, it must proceed to a first sterilization already upstream of the distillation body in order to prevent the formation of bacteria colonies on the membranes.
Potabilization methods are made in two ways:
- with lamps that emit ultraviolet radiation
- with addition of chlorine solutions to the liquid or ozone state.
In practice, the ultraviolet radiation disinfection system consists of a set of lamps housed in properly prepared conducts.
the chloration instead is carried out in the water, with appropriate dosing pumps, chlorine in form for example of sodium hypochlorite or, in the larger plants, of chlorine in the gaseous state. This disinfectant requires, in order to act, a contact time on average of 30 minutes, therefore after cloning you must leave the water in a tank called “reaction tank”. chlorine, in addition to altering the taste of water, varies the ph and can leave traces higher than the allowed limit, thus obliging to subsequent dechlorination process with activated carbon filters or with reducing products. essentially the system of hypochlorite disinfection is constituted by a mineralizer, a chlorinator, a reaction tank and a dechlorator.
Moseend, tell me what you think, because I think you're exactly on the same wavelength:"...the water is the basis of all life. seven tenths of the earth's surface is water. but do you know that for 70% is water?
- and like all human beings, you and I need pure water to replace our most precious fluids.
- You're starting to understand?
- Didn't you ever wonder why I only drink rain water or distillate? and only medicinal alcohol?
Do you know what fluorocontamination is? Water fluorocontamination?
fluorocontamination is perhaps the most monstrous plan that communists have ever conceived to our detriment
- he knows that besides contaminating water are also studying the way of contaminating salt, flour, juices, sugar, milk... to ice cream! ice creams, mandrake, children's.
- an extraneous substance is introduced in our precious vital fluids without the individual to notice or to oppose it. This is how he works, these unscrupulous people.
..."[cit.]
:smile:
