import 2d coordinates from txt file and join points with polylinees
  • Thread starter Thread starter Sfiffo
Sfiffo
Hello! are brand new and above all they are at first arms with cad (2008).
I wanted to ask how I could import 2d coordinates from .txt files (I found topic on importxyz but I didn't understand much). I tried to download "importpoints" but at the time of charging it it gives me trouble.
thanks in advance!
Okay done. I add he I am working for my three-year degree thesis on two-dimensional modeling of river alveo
and look importxyz I can't load it, I probably didn't understand where I have to save it.
As for importpoints now I can open it, open my .txt and set the various parameters but at the end it shows me nothing about the design.
But let me explain to you what I have to do so we understand better: I have a coordinate file north east in wgs84 and I have to put them on cad as a polyline to create the trend of the hive; I then have to copy the coordinates of the sections of my project (extracted by hec ras) and insert them on the polyline that represents the hive master, so as to be able to establish at what progressive distance they place.
Then I should go to measure all these progressive distances..I saw that you can do it quicklymeter right?
and look importxyz I can't load it, I probably didn't understand where I have to save it. . .
you must extract it into a search path of autocad support files:
download the program (zip file) and extract all files into a directory located somewhere inside your autocad search path. to load the program type (load "importxyz") on the command line and press enter. to run the program type importxyz on the command line and press enter.
...as for importpoints now I can open it, open my .txt and set the various parameters but in the end it shows me nothing about the design....
if you can attach the txt file containing the coordinates of the points to be generated.
....but let me explain to you what I have to do so we understand better: I have a coordinate file north east in wgs84 and I have to put them on cad as a polyline to create the trend of the hive.. .
so you just want a connection of the points to get a single polylinea. Right?
Yes exactly! Then I have to go to measure the distance between points to know where my sections are located
then, first I made changes to the file importxyz That I train. only worked in the English version of autocad. now he can turn on the Italian one. I didn't try all the functions, but what you needed is good.
If you have other problems loading the program let us know.
I attach the generated file of the river's upstream. with points and polylines.
I first created with importxyz the points on the layer points, then, always with this, I created the lines on the alveo layer. the lines were then transformed into polylinee with the command mpedit.
for other clarifications we are here.
ps: I realized now that I had made the same modification back and I had attached the file in This is what discussion, among other things reported above. :eek: this "forget" worries me! :frown:
Hello. I tried to use importxyz in particular the downloaded version in the attached files above.
I autocad 2010 and excel 2010, load the lisp but always tells me importxyz.dcl file could not be found.
I tried to make a couple of changes but nothing.
Can you help me? Thank you.
place the file in a folder between those found in\file\research path of support files, or add the folder to the path.
Hi I tried to run the file but I can't let it go, in the instructions I miss the photos and I don't understand what steps to do, if you can explain to me step by step how to make it work in autocad would be of great help. Thanks soon
