import 3d in dwg format in cocreate solid designer
  • Thread starter Thread starter Kaji
Kaji
I was provided with a folder containing two pdfs and two dwg in which the layout and the sections of a deformed gallery should be represented; He told me that there should be inside one of the two dwg also the 3d of the deformed gallery.
solid designer though the dwg directly matters them to me like 2d and in particular that concerning the sections I care soSezioni importate.webpI was kindly asking if someone could upload the file with a software that runs the dwg 3d and then attach the same in response in step or sat format.
thanks for availability
cmq looks that there's little and nothing in that dwg. only pseudopoints (which are not even points, are each 2 crossed lines) that I presume are beats within the gallery.
the points are there but they are on a frozen layer.
However it is true, of 3d there is little or nothing, moreover the data is very imprecise and chaotic. I'm sorry you have to work on a file like this, it must be pretty frustrating. ...
Unfortunately autocad converts only to .dwg . dws .dxf .dgn .fbx
