import aces
  • Thread starter Thread starter Arturo79
Arturo79
Hello, everyone.
I would have a problem: when I create an axis from PC "x" and open it from a different pc "y" (the file is transferred via e-mail), you can not see components such as welding cords, screws or bolted connections. How come?
Is it possible to solve this problem?
thanks for any answers! !
I'll throw it there... Are you sure that on the pc "y" there's the same library on the pc "x"? I think it's a problem of this kind.
Bye.
I think that's the problem, too.
You know how to solve it or better, you know how to add the missing library?
to me it seems that the library is there but it is as if you could not find the links.
I assume that being the file transferred via email, pcs are not part of the same network, is it?
I can't tell you how to do it, I don't know the sw but the various cads between the options have the folder setting that contains the files of the library.. .spippola a little....more could be that the two libraries are different and that therefore do not recognize each other.
ah, but is it inventor? then look between the options...there is the browse to the library!
hi! no pcs are connected on the net. for now we do not use the network because the operations are very slow.
non ho capito dove devo guardare...
the pack & go is sure on solidworks but there should be a similar system also for inventor. creates a package of files including bookcases ready for export.
Thank you! ! !
doing the pack & go first and then sending by mail the problem is solved! !
Maybe more than slow you don't have the network or the various inventors configured as you should, because even with a small network you definitely do faster than a pack&go + email.
undoubtedly does not have the stations configured correctly and has also said it. mainly you need to difine the project area and configure in the single area also the definition/files of the libraries. I don't remember how you do it anymore but when you open there are down buttons and options for management.
it could also be that it has a slow network, a first-generation wireless, a wired network with switches limited as first-generation wifi, a slow server... However in the immediate with the pack & go has solved. Then you'll see what to do.
We're actually waiting for the network to fit in.
What about the vault? Is it useful?
I never used it but should have its good advantages. the main is that the data is all encrypted, so you don't keep them anymore like the usual windows files. you have access with various administrative rights or not, you have the possibility to manage revisions and management of files in a more consistent way and with certain rules. eventually resembles a pdm, then also there depends on the version.
Okay thanks for the answer.
We will buy it in mid-September, hopefully it will be useful.
Hello and thank you for the answers! !
the vault is already understood!more than anything else is to be configured as you have otherwise they are just messed up!
