rugbyman77
hello to all, I would like to be able to import bright luminaires within the autocad map3d environment, so that you can create a brightness as likely as possible, it is an artificial road tunnel, which inside there are light fixtures with certain photometries, someone can tell me if it is possible to do so? or if it is the case of using other similar software? or if you can do it with bim software...
