import dwg 3d into inventor
  • Thread starter Thread starter gymbg
gymbg
Hello everyone.. .
I was given a dwg 3d autocad file and I have to open it in inventor.
I open a
new project
new standard assembly
amount dwg
the file opens to me, I visualize correctly but the odds I detect, both with the measurement option of the tab analyzes and creating a drawing file with the views in inventor are not correct. I have verified that they are not inches and in any type of scale... which can be?
probably during wrong import the settings for the units of measurement. (I tried both with detected units and also specifying mm)
... help me thank you!! !
Are the dimensions correct?
or between the dimensions detected in autocad and those imported in inventor that scale relationship have???
in autocad how do you have the variable measurement?? if it is = 0 you have to put it --> = 1
then try to import
eugenesis...
You're great. .
I autocad do not use it much and only basic commands... until now I never had a similar problem importing files into inventor.. .
setting measurement 1 and reimporting the file in inventor I get the correct measures (the same correct that I detect in autocad... )
Thank you very much!!!:finger:
