import features created parametric
Dromoaor
I wanted to know if it was possible from an import feature in any way make the design usable to change it via sketch and change its size. I have import features in .part.:biggrin files:
hi, no, it is not possible, because the import has algorithms other than those of the cad on which you imported.
this applies to any existing cad.
Only with the flexible modeling of creo can be made changes to imported mathematicians, but certainly not enter into a sketch as if it were an extrusion (which then the extrusion part, represents a possibility of the possible that I create has for modeling, such as surfaces, style surfaces etc.).
thanks always for the answer 320i s.
I tried to "recalcate" the geometry of the import feature taking as references those of the feature, but once purchased and made my design, if I go to delete the import feature, it automatically deletes all the drawings made by me because it loses the references the cad. is not possible to save the references independently whether there is or not the import feature?
otherwise it will touch me to draw the .part from the table .
Anyway, thank you for your help.
good work and good day
I tried to "recalcate" the geometry of the import feature by taking as references those of the feature, but once purchased and made my design, if I go to erase the import feature, it automatically deletes all the drawings made by me because it loses the references the...
just that in the sketch you delete from the reference card those that come from the import features. blocks all the odds you add, if you want to add the constraints and the game is made
Thank you for the answer.
I tried how you explained me and I can recalculate the design and subsequently delete the references of the feature, block all the quotas and after that gate the import feature makes me keep the parts of the design suspended with the symbol of non-regeneration (red circle with exclamation point next to every operation made). How do I solve this problem?
references are also the surfaces where you "support" to do the sketch and to orientate the sketch plan, so if these references are on imported mathematics, it is normal that if the gates, even the reconstructed features fall.
In fact, you can see that in your case there has been some dependence on the imported feature. try it with a dx key, info, reference display and you should be able to locate it.
