import file 3d cad 2010 your inventor 2012: problem!
  • Thread starter Thread starter Peppe.Giuli
Peppe.Giuli
Hello community,
I have difficulty importing a 3d cad file on inventor, I explain better.
I made the import of the file is I can not view all solids on the .ipt tab and the 2d diegno in .dwg, while in .iam I have all solids.
the question is just how to solve the issue, for solids in .ipt, I checked the measurement=1, but I can't find a different solution than to do everything about inventor!!
the goal is to assemble some pieces and add loads.
thanks to the collaboration! !
I'll tie the file down here.
Giuseppe
I didn't understand what the problem is.
if you imported the step together and you have all the inventor parts has already created the various .ipts that make up the axieme.
instead no, I have the .iam set but I do not have the single solids on the .ipt card
I ask a further question, can you export solids from .iam to .ipt?
Thank you! !
It's impossible, if he saved you a .iam, there must be its .ipt.
but what do you mean x .ipt card?
for export, I go to memory since I don't use inventor anymore, you have to select the solid you need and then export it.
I tried to open the annex with toptron, apart from the fact that we talk about solids and posted a dwg, inside there are only some entities scattered in the sheet.
I apologize for the delay in the answer, unfortunately I had some unexpected and I was not able to answer.
Thanks for the answer, I solved everything as you suggested and everything went to good end.
