import filet dwg in proe v2
  • Thread starter Thread starter cadmania
cadmania
Hello everyone.
I have made formats to uni norms in autocad 2012.
In order not to waste time I thought that in order to uniform the formats also in proe, I would only import the dwg files from autocad 2012.
But I never dealt with it.
Can you tell me or take the right path to solve this problem?
once you insert square and frame of the format in proe, I should then insert the text fields .
thanks to all
you can safely import the carcad from both dwg and dxf:
layout > import drawing/data
for the mask I suggest you start from a table where you can insert all the variable data managed through the parameters.
and if you want to import 2d files created with autocad (dwg) in proe
to be + precise I have a very complex section that I have to evolve the long a aretta, so I would like to create the section with autocad and then import it on proes
What do I do?
What do I do?
same system, layout > import drawing/data, and you can importredwg, dxf etc.
