import from autocad
  • Thread starter Thread starter ander
ander
hello to all....this is my problem: I received a three-dimensional .dwg file created in autocad, the amount in rhino and gives me the model in polygonal mesh, all joined together, and as I should make changes, I would need to explode it or divide it...but I can't. Does anyone know how to do that? :confused:
hi ander;
try this way:
test with the file>iser command.
call the file also with the .dwg extension and set on: insert as=single objects.
creates another layer.
nb; x delete the leyer you have to go on unblocking management. "modification>blocks/management blocks.
