import geometry from solid edge to adams/view
  • Thread starter Thread starter Frak88
Frak88
Hello everyone,
I am a mechanical engineering student and I am doing a fifth-year thesis where I have to learn from scratch and use adams for a dynamic analysis of a mechanism, used in automatic watering machines to flip bottles of 180 degrees and perform rinsing.
I am kindly asking with which format I can export the assembly, not only the geometry but also the relationships that are between the various parts I defined when I built the 3d model.
thanks in advance for availability.
I hope you can help me as I'm a little in crisis. :confused:
but what software do you want to export?
You also want relations between the various parts, so constraints etc.? I see it hard....
Hello xxfast,
I would like to export from solid edge st5. I would like to have the various relationships between the various parts I built in the solid edge axieme.
In theory you should be able to do if I don't err. . : )
Hello everyone,
I managed to export geometry with the parasolid format even if then the relations between the various parts I had to enter them in adams. Now I should impose on my object a law of myth that I have calculated in excel, someone can tell me how I can import this law of motion and impose it on the rotary motor that I have imposed in adams?
I hope someone can help me because I'm a little in the ball. ! !
thanks for the help in advance.
you need to build a spline function that then associates to motion with the cubicspline function
