import image to create path
  • Thread starter Thread starter paverik
paverik
a greeting to all,
I am a super hobbyist who likes to draw and make my toys through friezes and cnc lathes. (I'm a modelist) I attach two photos for pure satisfaction after so much work.
I have known for about a year this spectacular program I use often.
I need to create a path on a sketch plan 3 d of some order of a boat and then draw changes.
I have the original plans from executive drawing in pdf format, so you can want to save the various image formats (tiff jpeg etc).
I would be useful to be able to create the sketch of the orderly retracing the path of the image, a recalculation to understand;
Is it possible to import an image on a sketch plane? on solid edge you could also do sw?
thanks in advance
richer
Is it possible to import an image on a sketch plane? on solid edge you could also do on sw?
Yes, and typically to find these banal commands just navigate quickly in the menus :rolleyes:. . .
sketch/image tools/ tools of sketch.
thanks to the answer,
It is a really trivial thing I had predicted that I am a fleece, but it should be pointed out that for the command to be visible in the sketch tools it is necessary to generate any sketch otherwise generating only new sketch is not made clickable. This is obviously something you know very well, but for me, that I did not know, the thing made me look for hours the command in all the menus without finding it. perfect, I learned another one.
Thanks again.
richer
It's a really trivial thing I've predicted I'm a sink, my disconnect...
There is no need to disconnect, my advice was to avoid having to wait for answers here on the forum for such simple issues that are solved by the help.
However, it should be pointed out that for the command to be visible in the sketch tools it is necessary to generate any sketch otherwise generating only new sketch is not made clickable.
environment part, whether or not modified or created within the very top, as soon as you create the first sketch, you immediately have at your disposal the comnando for the insertion of images, regardless of whether you have created geometry in the sketch itself.
I, in the terms where you put the matter, did not know, but I probably did not understand what your problem is, because the command "image of the sketch" is inactive only if you create a sketch inside the axieme, on plans or faces of other parts. if you work together in part change The command is there and you can insert the image into the schetch inside the part.
