import lines excel
  • Thread starter Thread starter Andrea_Elett_90
Andrea_Elett_90
Hello, everyone.
I was wondering if there was a command or function where, from a file in excel interfacing blocks with attributes, and these are automatically compiled to the insertion of the block.
I'll explain.
-from a spreadsheet in excel I would like to extrapolate the information contained in the rows or columns;
-I would like to interface them with blocks, which would be inserted in the drawing with the attributes already compiled in the correct manner.
the advantage would be a lower margin of error in the execution of work and optimization of times.
I mainly use an autocad oem application, but I also have a full autocad version.
Is there a command or procedure like this? Can I fix it somehow?
thanks in advance for availability :biggrin:
hi, thinking about it on two feet, maybe through vba of autocad if you also have the names of the respective blocks always in the table of excel you can insert in a drawing....if you want to try contact me
