import loads from a txt file
  • Thread starter Thread starter erf
erf
Hello, guys.
I have to perform a transient analysis with a load that varies over time (at each time interval I have a corresponding value of the load).
Since these values I echo them from a code made of matlab that writes the output of the carcas on a .txt file, I wanted to know if ansys can use these loads to perform the analysis. the answer I think is yes, I would like to know which commands to use (on how to use them then I see it, unless you have any example/tutorial that does to my case!)
Leonardo
