import money from cad to revit2018.
giorgiovarchetta
Good morning, I have this doubt, is there a way to import a solid from autocad to revit avoiding to generate only a block in revit? because I can't even add a homogeneous material to the imported money as a block, and if I explode I lose it all.
thanks in advance of the support, precise that I am a neophyte.
Have a good day.
creates a local model (as a generic model goes well) and imports the solid autocad into the in-place model, then explore it. so it should work.
If you don't want to use local models you can do the same in chargeable families. if it does not work with dwg try to export from acad to .sat (acis)
