import points from a txt file
  • Thread starter Thread starter &Marco&
when you open the click window on browse and select the txt file but I can't import the values in the tabellina below to create the curve...you know by chance how I can do...thanks in the meantime... .
Sorry to intrude in a minefield, but it's not by chance that those values must all be "real" and not "full." . ?
I'll explain. suppose we have such a first line of the .txt file
1.2, 3.4, 5
It can only be that vs.software accepts it so:
1.2, 3.4, 5.0If I wrote a fissure, I'm going back to my den and I'm not going out. . .
the problem is that by inserting the txt file doesn't automatically create the tabellina with all xyz points and I would become tuberculous to insert them all by hand also because they are different rows... .
I have the values written this way
x -50.154 y 23.184 z -45.893
x.... y... z....
and so on...if anyone has any ideas on a possible solution I am here... thank you
x.... y... z....
you formatted txt file badly,
try with what I attach you (values separated by [TAB].
try to purify records so that they are in .csv format, that is:
first
after
-50.154,23.184,-45.893
