import points from xls files
  • Thread starter Thread starter marcobrt
marcobrt
hello to all guys and compliments for the forum.
My problem is very simple, I have a xls table where I tabled the profile of a cylindrical cam, the values of the first column are degrees and in the second are mm, how do I tell inventor that the data of the first column are degrees?
I can import the points though I have the flat profile, on the x mm axis and not degrees and on the axis y the various values of the diameter.
I noticed that from the 2009 line there is the option "crea spline" automatically, which instead 2008 does not have....sig Mr.:confused:
thanks in advance
to import points into inventor you need a table where the first column represents x the second la y the third la z. points, in fact, in the space are defined by three coordinates, of course a point can not rotate on itself according to a given degree... .
the points, in fact, in the space are defined by three coordinates
Allow me to complete the sentence: in the polar coordinates, a point is uniquely determined non x,y,z bensi' It's just... from a corner and a carrier.. .
I would like to recompose the profile of the cam with a polar coordinate and a vector, the first column expresses the degrees and the second distance from a single point, a bit like xls when you tell him to insert a chart "radar".
Does anyone know how to do it?
in a "polar" coordinate system, inventor like any other software uses a "chartesiane" coordinate system.
inventor come any other software uses a "cartesiane" coordinate system
this time not complete, but I must correct that "anything". . .
staying in the autodesk house, an autocad draws indifferently in:
  • coordinates related cardssiane
  • relative polar coordinates
  • relative cylindrical coordinates
  • coordinates relative spherical
  • polar coordinates and topographic angles
I don't know inventor, but it seems strange to me that it only limits itself to the Cartesian. . .
Go be....:biggrin:
Anyway I understand....
I turn each point from polar coordinates to Cartesian and amount those!:finger:
I mean a three-dimensional parametric modeling software (inventor, sw, catia etc.).
cmq if you stop for a few seconds on the key import points and press f1 the guide is very exhaustive
