importare geometria creata in apdl in workbench
  • Thread starter Thread starter MarshallDTeach
MarshallDTeach
Good morning!
geometry (2d) of interest for my work has a complex sketch that I cannot
create with design modeler for which
I created two-dimensional geometry in apdl.
you can transfer the geometry created in apdl (keypoints areas lines)
in workbech?
thanks for the help
Allow me to disagree... if you managed to do a sketch in apdl I don't see how you can't do it in dm.
I answer your question...
if you pass by dm also import lines ... if you enter wb areas and volumes ...
use an igs format to load in both environments
the geometry in apdl do not create it by drawing directly the entities
but uploading the circumferences by reading from a .txt file
and carrying out Boolean operations.
what I want to do is save geometry so
created and import it into wb
go out with an iges file and amounts in dm or wb.
confirm that this geometry can be realized in dm
igesout,'geom,'iges',' ',1
