imported autocad designs
  • Thread starter Thread starter ocraM999
ocraM999
is it possible, when importing a revit autocad design, to store the original print settings of the file.ctb?
Thank you
I don't think that's possible.
revit allows to manage imports (and exports) by object, in relation to the properties of the leyer.
:cool:
probably wants to keep the line thicknesses (which in autocad are the colors.. )
then it is possible... but possible
I asked for this because I am working with users who use all autocad with a assigned file.ctb.
I would like to keep the same settings as others in print.
intervening in object styles I think you can set the thicknesses of the lines of an imported-connected file.dwg but, if amount-collect a new file.dwg we are from head.
If there is a make-up... ?
Mar
.....convert them to revit....
but do you print in autocad?
you could print user files using revit so you don't need ctb.
