imported feature transformation
  • Thread starter Thread starter PAnz3r™
PAnz3r™
I have the following problem:
I have a handle, which I need in a variety of assemblies and what else, the problem is that, since I understood of the past, it was made by a desinger of some kind that of course did not consider the fact that someone then could reuse or have to change the piece...the handle is a set of shells... or surfaces. . .premitting that I'm not very hard in the use of surfaces I would like to understand how to make at least usable the said handle solidifying it. ..because as it is now it does nothing but give me problems in the assignment phase. . .
I can screenshoot it, post it comes a bit hard for copy right question I think. ..however it is a prt, with inside only an imported feature, and it is a handle formed by itself shells of surfaces..that I can't really touch
alura resumo this thread because I need this thing desperately...I have to find a way to solidify this handle to make it manageable somehow in pro and .\
place the zip of the file
In the meantime I recommend you watch the help online
introduction to import datadoctor (pdf)
introduction to import datadoctor is a presentation based on exercises that shows how to repair the geometry of imported models in pro/engineer from external sources. By completing all exercises, you will learn how import datadoctor handles imported geometry and best practices to perform repairs quickly and efficiently.
