imported parts with punctuation in iproperties (2023)
cal_duccio
Good morning to all, I arrived on the forum looking for help and I always found the answers I was looking for but concerning this problem I did not find solution, briefly explain: importing a step on inventor 2023 the parts have punctuation in the name (in iproperties) and when I go to put the ballon of the part obviously these exclamation points are displayed. models are provided by the same customer of all time, but I never had this problem because I used inventor 2018 until two days ago.
I looked for a way to export the steps and import them that ignored the punctuation but found nothing, I would just have a replacement function in the table, so as to replace the exclamation points with nothing
if you have advice I am here thank you very much
If I interpret your need well, this replacement can be done directly by manipulating the disparities.SOSTITUISCI.webpI don't think import in 2023 instead of 2018 is the cause, unless you checked it on the same stp.
