impossible to cut wall curved wire ramp authorized
  • Thread starter Thread starter castello_di_carta
castello_di_carta
My dear colleagues, I have a question to ask you, to which I have been unable to answer:
how do I cut down the curved walls (for convenience of glass management) as the reference plane can not editate it and the slope of the straight ramp is different?
I tried to change the ramp with various solutions, or the same is not generated correctly or it gives me error. (revit use 2010 and to generate the ramp I used the function "rampa")
I accept a thousand tips. Thank you.
make a subtraction solid (wall chain) through a route extrusion.
the path selections with the ramp line, and a profile that must be greater than the wall section (which you have to remove at the highest point).
associate the vacuum with the wall by command: change> geometry cutting
gfrank thank you for the help, but I had already tried the method you edited, or maybe I am not able to use it. (my mistake is certainly how I realized the ramp, but all the other methods that I tried in its realization tells me that the perimeter is not closed, yet I cimo everything...:frown:- example, if I determine contour and "alzata" inizale and final, the same is not created or if it is generated incorrectly, it does not reach the upper plane, it seems a gonfia ect., if I urilizzo im
thanks again for courtesy, but if you have a solution for those edited above.. .
I add overlapping ramp "correct" and sail ramp.
