impossible to open and display the correct folder
Angelo2449
Hello everyone,
in autocad 2018, using the command > appload < always opens the folder there are the lisp that I intend to open.
I installed version 2021 and opens a folder that I can't edit (see attachments).
Did I miss something?
I don't understand the meaning of your question.
go to the directory where you have lisp that you intend to use!
unless you can change directories because the popup window features the locked directory choice curtain.
I would like that at the opening of the appload window, a folder always appeared, in my case the folder where I hold the .lsp files, instead I always open another folder.
then autocad does not store the folder you usually use.
in this case is a variable problem:
rememberfolders to set to 1
