impossible to print the map geolocation in autocad 2014
  • Thread starter Thread starter foz
foz
I inserted the aerial photo through the geolocation of autocad 2014 but when I mold the table both from the spacecart and from the model, you can not see!!!
is there a way to print it or should you please view it on a monitor?
ps. I used adobe professional, cute pdf, dwg to pdf...ecc
...because it's yet another autodesk uselessness!
It's not exactly like that. the fault this time is of microsoft that does not allow it because of licenses and copyright.
If you want a satellite orthophoto for profit, you have to buy it! (and that's right)
if aerial photo is used for educational purposes I think it is expected for universities a favor price (as for software licenses)
edit: ennesima? What are the others? no one compels you to use autocad; if you don't like changing software. . .
autocad use for 20 years... now... the nut is taken! ! !
...sometimes autodesk you should worry more about streamlining the work, thinking less about putting flowers that then turn out to be unusable. ..as in qs case geo...I lost time reading the guide set the drawing file and then I can't print it!...which means "I lost time"? ...that I go home at 10:00!!!...but it's just my opinion.
