inclusion of external project
  • Thread starter Thread starter Christian76
Christian76
a question about the projects:
We suppose I have 2 different projects, a and b
in one of the two I need the assemblies made with the other project.
I normally create a dervived component of the assemblies I need.
does not exist a system to say that the project also incorporates b?
so that I am free to use all project axioms b in project a ?
I think it's still conceptually wrong what I want to do, but I'd be comfortable.
Any ideas?
Any ideas?
or create a new project file that incorporates both folders, or to the project file a or b (decided you) add a path to "usually used subfolders" and put the path of the other project.
....or the project file a or b (decided you) add a path to "used subfolders frequently" and put the path of the other project.
but it is not said that b is a subfolder of a or vice versa.
the right thing instead is to set the path in " search paths working groups" (or something like that... I don't have underhand inv).
You're right I did so too, it's been a while since I did it....
