incorrect restraints
  • Thread starter Thread starter Agar
Agar
premise autocad 2006
they sent me a dwg file that has many polygons with various types of restraint. some variations to make one of which is shown in the attached file.
in rectangle no. 1 there is the restraint made by them;
the problem is that when with the brush I give it to other polygons, rectangle n.2, the triangles of the dash are different, they are no longer closed but broken segments. the problem occurs with all restraints that contain geometric figures closed to e.g. hexane (hex), stars.
I kindly ask how I could solve the problem.View attachment Tratt errati.dwg
Many thanks for the answer.
I ran two tests.
1 - moved the ucs origin from 0.0.0 to a point close to the deduction, done the deduction, works, triangles are right.
2 - selected the dash, inherited property, in the window on the left model I insert in origin x and origin y the values x y of the coordinates of the point on the lower left corner of the rectangle, I follow rigen, but unfortunately the dash remains wrong (cf attached dwg file) I kindly ask why it does not change.
3 - When I check the restraint to a polygon there is a way to assign it origin without moving the ucs origin from 0.0.0? View attachment Tratt errati2.dwg Thank you.
