independent surface coming together
  • Thread starter Thread starter Mirror
Mirror
Good morning, everyone.
I'm working with creo 2 and I need to make some surfaces independent from copies together, inside my sheet.
I premute that the geometry copy is disabled, and generally independent I make a surface through the comprimi geometry in the standard form of creo, but I can't do the same operation in the sheet module, as I can't find it.
Thanks to those who want to help me:)
there is no "comprehensive geometry" command in sheet metal, most likely because a sheet is not a classic solid, but basically a surface with thickness and making it "dead" mathematics with the comprim geometry, it would lose all the characteristics of the sheet (drawing or creating folds etc.
You could think of starting from a solid and then convert it to the end but I don't know how feasible it is with your maths.
thanks to the info, I will try to do so, in the end the result should not change.
However in the sheet module, there is independent geometry under the curtain recovers data, but without the comprimi geometry does not have a particular benefit to me.
