odisseo 18
we will have to make an industrial metal shelving for a storage, measures. two meters long, two meters deep one meter, some constructive suggestions . should support heavy loads, use profiled or boxed? Thank you.
then they have to be branded there....no jokestry searching on the internet companies that produce shelving, give you the loads that can sustain, if it does not have to be something special, it seems to me wasted starting from zero with design and construction.
I believe that when you can use commercial components it is cheaper and safer to go to this road.
even the cost gives you...
