infittimento dotted lines hidden on pdf published
  • Thread starter Thread starter MORENO100
MORENO100
Hello everyone,
I would like to try to start using the public command pdf to "publish" the masses on the table appreciating the high definition of the details , but I find problems with the restraints of the lines hidden in the drawings of large size (a2,a1) because they are too radiant.
someone knows how to adjust it, for example as I usually do with prints using the "plot_linestyle_scale" option.
thanks and good work.
p.s. use wf5 and creo2
solved.
I couldn't find a config option that gives me the opportunity to manage the filing of the pdf drw files.
but I solved the problem by creating various .pnt files for each paper format, a4,a3,a2,a1, varying the values of the "pattern" of the corresponding pens.
the only problem he encountered was about the pen of hidden lines, I solved him "attention_color" with "half_tone_color" as suggested in another discussion.
