SATURNO07
Hello I have seen that on the r21 does not make me do cavity and portacavity in the section core and cavity... I explain better
on the r18 I used the command "direction of extraction" and it made me become the two parts of green and red (naturally if you sform :biggrin: ) and divided them into cavities and portacavities directly into the tree on the left....instead with the r21 it makes me become the two green and red parts, but it doesn't divide me it puts them in the tree... how do you do it??? there are other commands? ? ?
I also attach an image of the command that I should use...graize :d
