info dalpuntatore
  • Thread starter Thread starter carlo1149
carlo1149
Good morning to all
work with the 2008.1 version of thinkdesign
and is installed on three pc stations,
on one of these if I stop with the pointer (the dart) on a corner of a component I will see the following information:
component: component name xxx / curve length mm xxx
on the other two positions only shows me the information length of the curve mm xxx
how can I do to have on other posts the component name too?
to view component information you need to set the selection of thinkdesign to top component:
find the command in the selection toolbar.
In the options of the document, if I'm not mistaken, you can also see location and quantity. .
Matteo
while I thank you for your answer
I don't understand.
I go to the "modification" drop-down menu and there I find "select", it also opens this and I find select chain , select everything etc.
but here I do not seem to be able to set anything but only to be able to choose the way to select the drawn entities.
Could you please bend me better as you proceed even when you say that in document options I find the possibility to view location and quantity?
1000 thanks
car
Bye. .
then
You need to open the model you're working on
among the various standard toolbars that you have at your disposal there should be one that is called select that you see below:
attachment.php
the icon I have indicated allows you to choose between 4 modes:
  1. Faces
  2. solids
  3. leaf components
  4. first level components
The mode you need to use is that of first-level components
in this way thinkdesign selects only the components and not the racked entities in them.
In the system property, find the voices that I've indicated here is an example.
attachment.php
Now I do not remember if these flags with the 2008 version were where I am pointing to you or were in the configurations of tteam ..
soon
Matteo
really 1000 thanks for your precious advice
that will allow me to work better.
car
