info field author in cartiglio
  • Thread starter Thread starter sbronzo
sbronzo
I wanted to ask if someone knew how to change the vampo author inside the cartiglio, or rather:
the cartiglio that we created takes the name of the author in automatic for example: xxxxx.xxxxx that I think it is also the name of the machine when you log in from windows.
You know if this can change? ? ?
I would say from the properties of the file (.psm, .par...etc...)
If I go to file, the file property appears to me the author's name but even if I save it by putting in my this does not remain.. .
I think he's going to read a field inside the registry or something. .
if you refer to the field %{author}, simply go to take the name of the current user of windows. If you want to change, you need to change the name you log in with, which you can get with the command:
start-->exegui-->control userpasswords2 performed as administrator.
Do you have any idea if changing the username you may have access issues to the company network?
If you are inside a domain I would say yes, another solution can be a custom property to call back in the cart.
I solve the problem by calling the network administrator and making me change the name....
