info fori filettati
  • Thread starter Thread starter and
and
Hello.
My may be a trivial question ..
but how do you recognize threaded holes if you import a 2d design on the cad/cam (eg. .dxf) or 3d (eg. .iges)
from .dxf you should see it as in a table.
on the 3d file you have no way, unless you already use file step with the annotations inserted.
If the cam is not the same as the cad is difficult, I with my customers solved the problem with the colors of the faces, because many cams recognize the colors to select the types of holes.
