AlessioOvo
I have realized a part with unit of measurement in mm, is it possible without unscrewing it multiply together all the quotas x 10 mm and keep the mm? without using features?
or changing the scale in practice? ....I don't know if I explained I have mistransformed the mm instead of 5,3 should be 53 mm and so I should turn it into cm to keep the 5,3 or multiply them all by 10 to maintain the mm and then transfer it together and bind it to another component with the right size... without changing all quotas can I change in block?... can you do such a thing or am I forced to multiply them by 10 one to one? . . .
